Easy recipes for caravanners: No-bake sweet treats
By: Lynn Bain
Using an oven isn’t always an option when you’re on the road.
Satisfy those 3pm cravings with these delicious (and easy!) no-bake sweet treat recipes.
No-bake chocolate bars
Chocolate -bars
These bars are a luxury nibble for those times when you have done a big walk or simply feel like spoiling yourself.
Handy Hint: You can use either dark, milk or white chocolate for these bars. You can also add a glug of dark rum to the mix. If you have used white chocolate for these bars, you may like to use a dark chocolate for decorating purposes.
Preparation time: 10 minutes
Cooking time: A small amount of simmering.
The following quantities will make approximately 12 bars.
Ingredients
275g dark chocolate, roughly chopped
175g butter
4 tbsp golden syrup
175g biscuits (such as Nice)
4 tbsp rice bubbles
2 tbsp chopped nuts
50g dried fruit (such as craisins or chopped dried apricots)
25g white chocolate, to decorate the bars (optional)
Method
In a large mixing bowl, place the chocolate (whatever type you choose to use), butter, golden syrup and rum (optional). Place the mixing bowl over a saucepan of gently simmering water. Stir the chocolate mixture until it has melted.
Crush the biscuits into small pieces and stir them into the melted chocolate mixture. Add the rice bubbles, nuts and dried fruit.
Line an 18cm square (or similar) baking tin with either baking paper or plastic wrap. Pour the chocolate mixture into the tray and smooth the top with a long knife. Place the tin into the fridge or cold box and chill for a couple of hours.
To decorate the tops of your choc bars with another chocolate variety, I like to let my choc tray set in the fridge while I then melt the chocolate for the decoration over a pan of simmering water. Drizzle this freshly melted chocolate over the top of the half-set chocolate in the tin; drizzle this in a random pattern. Allow the decorations to set (into the fridge again with the tray). Finally, turn the chocolate out of the tin and cut it into bars. These bars will last in your fridge or chiller for at least a couple of weeks. Surely you’ll have eaten them by then!
Fudge bikkies
Fruit -fudge -bikkies
Handy Hint 1: I have used glace ginger in this recipe; however, you could also use either glace cherries, finely chopped dried mango, or glace pineapple.
Handy Hint 2: You could also use dark, milk or white chocolate in these fruity fudges.
Preparation time: 10 minutes plus an hour to chill
Cooking time: 5 minutes (on the stove-top)
The following quantities will make about 36 pieces.
Ingredients
1 tbsp water
90g butter, cubed
250g pack of mini marshmallows
200g chocolate, broken into pieces
2 tablespoons finely chopped glace ginger
Method
Place the water, butter and mini marshmallows in a heavy-based saucepan. In the saucepan, cook over the lowest heat possible until the butter and the marshmallows have melted. You will need to stir continuously during this process.
Remove the saucepan from the heat and add the chocolate pieces. Continue stirring until the chocolate has melted completely. Add the ginger pieces to the mixture and stir through.
Line a shallow dish or tray with plastic wrap. Drop teaspoonfulls of the chocolate mixture onto the plastic wrap about 1cm apart. Place the tray in the fridge or chiller box to set. When set, remove the fudges bikkies from the tray and store in a container in a cool place.
Seedy bars
Seedy -bars
Handy Hint: Vary the nuts and seeds in the ingredients, obviously with a heavy emphasis on adding extra of your favourite type(s).
Handy Hint 2: The following instructions melt the peanut paste and butter in a microwave. However, you could also do this step on the cooktop, or over a campfire.
Handy Hint 3: I prefer fresh-shredded coconut rather than desiccated coconut.
Cooking time: 2 minutes
Ingredients
2 cups sesame seeds
½ cup sunflower seeds
½ cup dried pumpkin seeds (pepitas)
1 cup Rice Bubbles
1 cup shredded coconut (optional)
3 tablespoons low-fat peanut paste
½ cup honey
A pinch of salt
½ cup unsalted chopped nuts
Line a shallow baking tray with plastic wrap.
Method
Combine the sesame seeds, sunflower seeds, pumpkin seeds, rice bubbles and coconut into a large bowl. This is Mixture 1.
Mix the peanut paste, honey and salt in a microwave-safe bowl and microwave for about half a minute. Remove the bowl from the microwave and stir well. Continue to microwave in short bursts until the peanut paste mixture is runny. This is Mixture 2.
Add Mixture 1 to Mixture 2 and stir quickly and gently until they are well combined. Press this mixture firmly into the lined baking tray. Sprinkle the chopped nuts over the top and press them into the seed/peanut paste mixture well.
Place the tray into your van’s fridge, your portable fridge or cooler box, and chill until the mixture in the baking tray is set.
Slice into squares and store in a cool spot.
The full feature appeared in Caravan World #521. Subscribe today for the latest caravan reviews and news every month!
