Installing a D035 Offroad Hitch
By: Max Taylor, Photography by: Max Taylor
We look at what’s involved in swapping your coupling to an offroad Hitchmaster DO35.
Perhaps the most pertinent reason to change your coupling is to match your rig’s capabilities to the terrain you want to traverse.
Why change your coupling?
There are a few answers to this question but, perhaps, the most pertinent is: to match your rig’s capabilities to the terrain you want to traverse.
Standard 50mm ball couplings have an inarguably important place in the market but their limitations have given rise to a swag of all-terrain couplings that articulate on both horizontal and vertical axis. The benefits are obvious: as you bump and grind along undulating tracks, the vertical movement of the coupling removes the stresses from your equipment. Tackling a low-range track with a standard ball coupling has bent towbar and cracked A-frame written all over it.
Naturally, you’d only swap to an offroad or all-terrain coupling if your van has the credibility (and, dare I say, warranty) to handle that sort of terrain. But the good news is, with a couple of caveats, it’s relatively easy to swap one coupling for another.
If the coupling you want to replace is welded to the A-frame, the task becomes much more complicated. You’ll need an angle grinder, patience and a steady hand. But if the coupling is simply bolted in place – as many are – you’re in for a much easier day. It’s obviously important, too, that the stud pattern of the coupling you want to fit aligns with that of
your A-frame.
FITTING THE DO35
The first step is to remove the old coupling. In this instance, we wanted to replace a polyblock Trigg unit with the well-regarded Hitchmaster DO35 by Vehicle Components. This is a coupling with which we’ve had plenty of experience in both offroad and highway conditions.
The first step was to remove the old coupling – a simple matter of unbolting it from the A-frame and disconnecting the integrated handbrake from the handbrake cable.
With the old coupling removed, it was time to fit the DO35. This coupling comes with six bolt holes, with a minimum of four bolts required by Vehicle Components (for vans under 2500kg ATM – six bolts are required if the ATM is above 2500kg) for securing the coupling to the A-frame. Because the original coupling was only secured by four bolts, our van’s A-frame only had four holes to work with. But since our van was well under 2500kg, we were able to confidently proceed, without drilling additional holes.
Vehicle Components recommends using M12 class bolts or 1/2in Grade 5 bolts with nyloc nuts or spring washers, tightened to 75Nm or 90Nm respectively. At this point, it’s worth adding some multi-purpose grease to the coupling via the grease nipple. You’ll need a grease gun for this.
Then, you can reconnect the handbrake and fit the supplied tow ‘pin’, which directly replaces the conventional towball – no other components required – tightening the nut to the recommended 440Nm.
With your van now fitted with a serious all terrain coupling, you’re ready to go bush!
The full feature appeared in Caravan World #540 August 2015. Subscribe today for the latest caravan reviews and news every month!
